How would this be?
Jeremy1976
How would this be? - 11.07.2007, 05:45 PM
MM with UBEC on 4s with 9XL??? Would that push my Revo pretty good? I am talking 45+ mph with good wheelie power??? I just got my Tekno conversion and I am having a hard time holding off for the MMM and Neu motor package. What do you guys think? Anyone have a video of this setup? Thanks
11.07.2007, 05:53 PM
That setup is a decent setup for moderate speeds (~30-35). But 45mph+ will require tall gearing and might stress the ESC and batteries to get there. For faster speeds on something as heavy and large as a Revo, you really want 5s or 6s on an appropriate ESC and motor. Gotta remember that the MM, 9XL, and 4s is just about the cheapest setup you're gonna get and will not have super high power like the more expensive setups.
Jeremy1976
11.07.2007, 05:54 PM
Okay I will wait then. I want a minimum of 45mph and wheelies at will. Thanks for the input.
11.07.2007, 05:59 PM
No problem.
Actually, do you plan on locking the tranny in second, or retaining the 2 speed? If you keep the two speed, you can gear it for ~28-30 in first, and then 2nd gear might be able to hit 45. This might be your best bet for the price considering your goal as long as you can live without reverse and using a brake servo...
11.07.2007, 06:15 PM
http://www.rc-monster.com/forum/showthread.php?t=7926
For videos
9XL 4S MM is great... Seems a near perfect entry setup and will hold me until the MMM Nue...
I've now three of these setups in a REVO, MBX5T and X1CR...
11.07.2007, 06:17 PM
MM can be re-sold in a heartbeat for almost list price... 9XL's can be had for 60
Go for it...
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
11.07.2007, 06:19 PM
I'd say go for it. Having fun while the MMM debuts is priceless!
:D
Jeremy1976
11.07.2007, 06:28 PM
No problem.
Yes I got the Tekno conversion that retains the stock Revo trans. I got the forward only control already in it and plan on keeping it a 2 speed. I will be using a servo for the brake. Thanks, as I said I will more than likely just hold off then it is winter here in wisconsin anyways so I can wait. I just got the conversion today and got kind of impatient. I got the front and rear end already transferred over to my 3.3 chassis. Thanks
Jeremy1976
11.07.2007, 06:29 PM
For videos
That is crazy!
11.07.2007, 06:36 PM
Exactly... So why wouldn't you go for this :)
Matthew_Armeni
Matthew_Armeni's Avatar
11.07.2007, 06:40 PM
The highest you can gear with the Tekno setup is 18/34 (for sure) possibly 19/34. If you install the wide ratio gear set you're still only looking at about 40 top speed. Either go up in cells as Brian suggested or get a hotter motor, 8XL or 7XL, if you want to go cheap, or if you want something better, a neu 1515 1Y geared 18/36 with the wide ratio should give you 45mph, if the winds behind you. That's fast though, I can try to get a vid up of my Revo, look at my sig for setup info, it's basically what you are talking about running. I'm pretty happy with it, but I still have the standard ratio, plan on getting the wide ratio soon. I'll try to get the vid up by Fri, if you haven't bought anything yet I'd suggest the neu motor, a 4S pack, and a MM. So your only real expense will be the motor.
  Send a message via AIM to Matthew_Armeni
Matthew_Armeni
11.07.2007, 06:41 PM
wow, 4 posts while I wrote my 1
Jeremy1976
11.07.2007, 07:02 PM
Thanks for the info. I think I will go with the Neu that you mentioned and a 4s. I think I will hold out for the MMM though. Any idea when it is to be released?
Matthew_Armeni
11.07.2007, 07:09 PM
No idea on the MMM, but the MM can handle the 4S with ease. Unless you're going to eventually go up to 6S the MM should be fine and all you'll need to do is get a BEC. Or run 3S, a hotter Neu, and no BEC, that works too.
11.07.2007, 07:52 PM
February is looking likely for the MMM.
