Spur gear adapter
Cartwheels
Spur gear adapter - 11.07.2007, 11:49 PM
Here is a spur gear adapter that can adapt the 51t to center diffs like the Jammin CRT, Losi, and a lot of others. It looks like plastic but it is metal. I think it will also work with a 62t gear also.
http://www.horizonhobby.com/Products...odID=MUGZMT008.
There are few others that sell this adapter. It is made by Mugen. Here is the part # MUGZMT008
This might be a good part for Mike to carry.
11.07.2007, 11:59 PM
Nice find!
starscream
RC-Monster TQ
starscream's Avatar
11.08.2007, 12:19 AM
Mike custom made two of these for me.
That speaks to the kind of over and above service he provides.
Ha Ha
The Flashlight Strikes Again...
Cartwheels
11.08.2007, 01:09 AM
Mike has made one these for me too. His are better because they are aluminum and much lighter wieght. But the Mugen adapter isn't bad for being ready made.
Cartwheels
11.08.2007, 01:32 AM
Spoke too soon I guess. Its not perfect. everthing seem to look like it was going to fit, but now that I trying it again, I noticed the hole for the drive cup shaft in the center of the adapter is only 5mm and needs to be 6mm. I think I will drill mine out. The only thing is, I think it is hardened steel.
Cartwheels
11.08.2007, 02:21 AM
Ok, it was simple fix to drill out. It's not hardened. I used a 15/64 drill bit and about 1-2 minutes of filing with a round file (6mm drill bit might be better). Now it is good to go.
nl12
nl12's Avatar
11.08.2007, 08:39 AM
how did the holes line up on the spur gear and adaptor, I have these same parts, and they didnt line up very well, how did you make it work? Thanks
Dafni
Dafni's Avatar
11.08.2007, 08:50 AM
Proper way to modify this would be to ream it out on a lathe. You want a precision fit there, otherwise you might get a leak and a wobbly outdrive.
Daf
dadnjesse
11.08.2007, 10:39 AM
Would that work in an Emax? How would you attach the center diff?
starscream
RC-Monster TQ
starscream's Avatar
11.08.2007, 03:10 PM
If you don't have a lathe, it seems the best use for this adapter is only with a Mugen dif as I don't know of any other manufacturers using 5mm output shafts.
Ha Ha
rchippie
rchippie's Avatar
11.08.2007, 08:13 PM
Remember the mugen uses 5mm out drives & most other buggy's use 6mm out drives. So if your using this on any buggy other than a mugen your outdrives may not fit.
REAL MEN RUN BRUSHLESS
Cartwheels
11.10.2007, 01:27 AM
Sorry but this didn't turn out to be the easy ready made spur adapter I was thinking it was going to be. I was able to make it work but one of the toughest things was after I drilled it out for the 6mm out drive the recess for the O-ring was too small. With a lathe this may be an easy fix, maybe.... I used a drill to spin it and a dremel to make the recess bigger. also the screws holes to mount this adapter on the diff need to be about .5-.75mm further out. There was some other work I had to do to this thing to get it to work too. All in all, it's not an easy deal.
