Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
revo hybrid center shaft options
raven824
revo hybrid center shaft options - 11.08.2007, 05:18 PM
what are the feasible options to get center driveshafts for the revo hybrids v2
Serum
Serum's Avatar
11.08.2007, 05:45 PM
Shoot Mike an email, and i give you a 100 percent change of success.
david lamontagn
11.08.2007, 07:23 PM
And when you get an answer from Mike, please, post it here because i'am asking the same question.
I think that this will be a beautiful headache to find a center drive shaft who'll fit the 8mm diff outdrive on diff side and the 6mm stock revo trany output shaft on the tranny side
Serum
Serum's Avatar
11.09.2007, 02:47 AM
My idea was to make an 8mm adapter that would fit the stock driveshafts and the 8mm pinion.
david lamontagn
11.09.2007, 09:11 AM
The problem is to find a 8mm output with a 6mm hole in it. Like that, we could drill one to 8mm.
Serum
Serum's Avatar
11.09.2007, 12:49 PM
I guess you don't understand what i mean.
Make an 8mm revo shaft drive-dog.
david lamontagn
11.09.2007, 03:46 PM
Excuse Serum, i'am a french guys and some english expression i don't understand.
Could you explain what's a 8mm revo shaft drive-dog?
Thank you!
david lamontagn
11.09.2007, 03:49 PM
OK Serum i think i understand now, you say to make a special adapter to slip over the 8mm pinion diff, to use the stock revo slider?
I was thinking to just drill the stock revo center shaft yoke to 8mm and drill a hole in the 8mm diff pinion, like on the V1 modified pinion, and use the stock revo drive shaft pin to "lock" the stock yoke on the new diff pinion.
Serum
Serum's Avatar
11.09.2007, 03:53 PM
here is what i mean;
These are the center revo shafts, and here is the cup i drawed to be made in steel to fit the revo driveshafts (it only uses an 8mm hole and is slightly larger on the end)
david lamontagn
11.09.2007, 03:58 PM
Well, beautiful part.
But where can i buy it?? do you sell it? Or is Mike sell it?
Serum
Serum's Avatar
11.09.2007, 04:09 PM
Mike has the STEP and IGES drawings (files needed for CNC machinery), i made it for him half year back or so. I don't know if they ever went into production
david lamontagn
11.09.2007, 04:17 PM
So all i have to do is e mailed Mike and hope that he can make it for me, but i know that he's very busy..........
If he can't make it, i'll have to look for another solution.
Thank you Serum!
But if i drill the stock drive shaft hole to 8mm and drill an hole in the diff pinion to put the stock revo screw pin, do you think that this will hold?
11.11.2007, 07:27 PM
Though the plastic yolk/ joint might be weakend abit by drilling it out to 8mm, it should be okay since they are very beefy items. The only problem I forsee is drilling a hole into the 8mm pinion shaft- there is a nice big flat spot, but it is hardened steel I think....
