Which is the better setup?
AP Alex
AP Alex's Avatar
Which is the better setup? - 11.17.2007, 11:17 AM
Which is the better setup? MM 4600 on 3S or MM5700 on 3S What gearing should I start with. I'm running a 54T Spur need help on the pinion size.
cart213
cart213's Avatar
11.17.2007, 11:19 AM
What vehicle are you putting it in?
AP Alex
AP Alex's Avatar
11.17.2007, 11:44 AM
I'm putting in a Jato.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
11.17.2007, 11:48 AM
I would go for the 4600....
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
cart213
cart213's Avatar
11.17.2007, 12:29 PM
It depends what you're going for. If you want all-out nitro-beating speed, go for the 5700, but it will run hot and may thermal sometimes. If you want a more reliable setup that will run cooler but not be as fast, then get the 4600.
I can't help you with the gearing, since I've never had a Jato.
