Originally Posted by Matthew_Armeni
Well they all have 5mm shafts, so I don't know what you're going to do for pinions. Also the ones you suggested are a tad longer than a typical 540 motor, not a bad thing though. Anyway, the shaft size is the biggest problem.
I might pick up one or 2 of these motors, that price is so low.....
Thanks for your input. If I'll go with Rusty pinion is not a problem because Mike have 32 pitch with 5mm bore pinions, but E-Firestorm spur´s pitch is 48 and that is a problem?
Those motors was just an idea, but I think that I´ll buy E-Firestorm and get motor that can use with stock pinions. Don´t know yet.
