Rust/Stam Ext Arm Conv -
11.29.2007, 12:08 PM
We machined a new extended front arm to match with our extended rear arm.
Due to a lot of feedback from Rust/Stam owners wanting to run the same offset wheels front to rear. The only arm kit that would allow you to do that was the FLM248000 Arm Kit. So we designed an extended front arm to go with our extended rear arm which was the FLM24900 Arm Kit and still will be the same part # we will just replace the front arms with new front arms.
Also the arm will be available separately for those who already have the 24900 kit.
Another note affecting all arm kits. The turnbuckles have been updated to the larger diameter VXL rod ends.
