Plastic Kyosho spur vs MBX5 and RC8 doffs
david lamontagn
Plastic Kyosho spur vs MBX5 and RC8 doffs -
12.02.2007, 12:37 PM
Is somebody could tell me if the plastic Kyosho spur will fit on the Mugen MBX5 center diff cup and on the new Associated RC8 too?
thank you!
david lamontagn
2
jnev
12.02.2007, 02:33 PM
It does not fit on the RC8, but I am not sure about the MBX5...
jnev
Find all posts by jnev
3
david lamontagn
12.02.2007, 03:13 PM
That's good, i'll order it and try it.
Thank you!
david lamontagn
4
rchippie
12.02.2007, 05:26 PM
Originally Posted by
david lamontagn
Thank you!
It will not fit the mugen diff. Mugen diffs use 5mm outdrives & the kyosho gear is for diffs with a 6mm outdrive.
REAL MEN RUN BRUSHLESS
rchippie
Find all posts by rchippie
5
Cartwheels
12.02.2007, 10:42 PM
Not sure what your looking for but, for the Mugen you could use this
http://www.gshobby.com/index.php?mai...oducts_id=9848
with a ofna 51t spur gear.
Cartwheels
Linear Mode
Switch to Threaded Mode
