What Neu Motor for Revo ?
austinmaxx
What Neu Motor for Revo ? - 12.04.2007, 06:34 PM
I just bought the MGM 160 controller and the Neu motors have been out of stock what Neu or Lehner motor do you suggest for a Gorillamax Revo, would like to do 45 if I want but its mainly for bashing, I will use lipos how many cells will I need to run also? When will the Neu's be back in stock? Also do I need to use a fan on the MGM? Thanks
david lamontagn
12.04.2007, 07:06 PM
Neu 1515, 1Y, on 4s li-po, that's a beast
No fan at all on the MGM or the motor
jnev
jnev's Avatar
12.05.2007, 12:16 AM
Yep, what he said. You should be able to reach 45mph quite easily with the correct gearing on the 1515/1y (2200Kv) on 4s lipo.
Finnster
KillaHurtz
Finnster's Avatar
12.06.2007, 12:21 PM
The motor depends on the number of cells you want to run. The MGM would be good on 4-6S lipo.
For 4S: 1515/1Y 2200kv: 120A capable lipos needed; ~5000mah 20C cells min
5S: 1515 1700kv; 100A lipos; ~4000 mah 20C cells min
6S 1515 1500kv; 80A lipos; ~3300 mah 20C cells min
All will be strong performers, w/ about the same power output. The 6S/1500kv would be the coolest running, and likely the most powerful as the motor efficiency is highest, and would give a little bit more rpms, and could be tolerably geared the highest.
Finding chargers & balancers capable of 6S packs is a bit more tricky than 5S and below however. So a 4 or 5S setup is most convenient. The above recc packs will all give approx same runtime, and all are ~500g. Add more mah if you don't mind the weight for more runtime.
The boss setup would be 1500kv on 6S, and a NeuEnergy 3200 6S pack (500g), or a 3900mah pack @ 600g for the longest runtime. If you want crazy speeds (breaking 50mph) the 1700kv motor w/ the 3900mah pack would so it, but all will do mid 40s easy.
Its my understanding that Neu is selling motors as fast as they can make them. Leadtime is 4-6 weeks. Instead of waiting for stock, I would order the motor I want and wait. Perhaps if Mike already has that one ordered you'll get it a bit faster and it would be reserved for you. Mike can also get any other Neu lipo packs that may not be listed on the site.
tmaxxdaddy
Mega-what's?
tmaxxdaddy's Avatar
12.06.2007, 07:23 PM
I'm new to brushless as well.
I was wondering the difference between 1y and 2y I found alot of technical stuff, But I need layments terms, (not just the tech stuff but maybe the performance diff)
Thanks
crazyjr
crazyjr's Avatar
12.07.2007, 12:56 AM
I run the 1515/2.5d/f on 5s and its an animal, running 5s and a 20/51 (mod1) its running about 40 and never gets warm
