reversing motor position with Gmaxx motor mount?
jordan...
one.five.two.seven
reversing motor position with Gmaxx motor mount? - 12.04.2007, 09:48 PM
hi guys, me again
just wondering what advantages there are of reversing the motor with the gmaxx chassis, ie. hanging over the rear plate, and do changes have to be made to the channels or something to make the car move in the right direction due to the reversal of the motor?
an example of what i mean:
http://www.unlimitedengineering.com/...p?i=2204&c=193
thanks again
jordan
entjoles
12.05.2007, 12:14 AM
with the motor facing to the rear you dont have to flip the diffs, which you really dont have to do , you can change motor direction by switching two wires
the novak systems require the truck to either have the motor in the rear or flip the diffs
jhautz
jhautz's Avatar
02.05.2008, 10:30 AM
I actually did not like the older gmaxx reversed motor mount. It made changing the spur gear a nightmare. I personally would recomend jut jeaving it in the stock position or use the new gmax motor plate.
to make it...
or break it...
Silent...But Deadly
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
02.05.2008, 05:33 PM
you can also turn the tranny around to switch the direction
02.05.2008, 09:20 PM
With the stock type mount, correct. I have the X-brace motor mount, and it does indeed make changing the spur a nightmare, but with the single speed conversion all I have to do is unbolt the tranny, undo the front drivecup from the tranny output shaft, and the whole tranny slides forward enough to change the spur gear.... no hassle at all, lol. Plus the mount flexes rather alot with the motor mounted at the highest point in the middle- i am working on a bracing system that should fix that issue hopefully.
jordan...
one.five.two.seven
02.19.2008, 10:02 PM
atm I do have the new Gmaxx plate, but I was afraid that the motor/ESC wires would be a little long because i'd have to run the wires from the front half of the chassis to the back top plate where i'm going to mount the esc.
Would this extra length cause any excess heating due to resistance?
jordan
02.20.2008, 03:38 PM
There is a beautifully simple solution to that- just flip the entire tranny around 180*. You will ofcourse have to flip the diffs too, but that way the motor wires can be shortened rather dramatically for a cleaner look.
