Only has a 50W max output so for 5s it means that you can only charge at around 2.7amps, which means around 2 hours to charge a 5000mah 5s pack.
Based on 50W max output or 5A charger maximum.
5s = 2.7A max charge rate
4s = 3.3A max charge rate
3s = 4.5A max charge rate
2s = 5.0A max charge rate
I thought they looked nice too untill I found that out. Its great if you only charge small packs or everything is 2 or 3 s. But for 4 or 5 s large capacity packs its somewhat less than ideal.
Other than that I have seen a couple people use them and they looked nice and easy to use.
to make it...
or break it...
You are right, but you can't expect a $75 charger to perform like a $175 Hyperion charger.
Happy Holidays,
Al
agreed...
I just wanted him to be clear on the actual performance he should expect. The specs don't mention the 50W max. They just say 2 to 5S and 1.0 to 5.0 amps capable. Which is not the whole story.
I actually think they are pretty nice for the $$$
to make it...
or break it...
