Do Kyosho spurs fit the 8ight?
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
Do Kyosho spurs fit the 8ight? - 12.19.2007, 05:59 PM
The 9-11 tooth pinion gears I have don't appear to be hardened nor can I seem to find any truely hardened 9 to 11 tooth mod1 pinion gears, so I need to find a plastic spur that fits the Losi 8ight.
Area 52 Ranch Raceway
T.R.C.R.
lxmuff
lxmuff's Avatar
12.19.2007, 06:14 PM
The 46T Kyosho will fit
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
12.19.2007, 06:50 PM
I tried the plastic kyosho spur trick on my hyper 7. Sure it "fit" but it didn't seal worth a damn. Leaked all over the place, and wouldn't keep any fluid in the diff. Save yourself some heartache and buy a hardened pinion.
Not sure if it's a better seal on yours, but I'm betting no.
Sleeb
SpEEdyBL
SpEEdyBL's Avatar
12.19.2007, 07:56 PM
Thanks guys. I think i might give it a shot since its only $5.
T.R.C.R.
rchippie
rchippie's Avatar
12.19.2007, 08:09 PM
Sleeb
did you use a paper gasket ?. I've used that spur on it two different cars a jammin & a losi with out issues.
REAL MEN RUN BRUSHLESS
gixxer
gixxer's Avatar
12.19.2007, 08:35 PM
I never had a problem with it sealing on my 8 or 8t either.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
sleebus.jones
12.19.2007, 09:28 PM
No, sure didn't. I used the thin orange o-ring that was on the diff, so maybe that was the problem. At any rate, I ended up having to change to steel for durability. The plastic Kyosho didn't hold up well to 2,500w+
Sleeb
aqwut
Brushless Heavy Weight....
aqwut's Avatar
12.19.2007, 10:18 PM
Sleeb
that's a lot to ask from a $3 plastic....
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
BP-Revo
BMW M Power!
BP-Revo's Avatar
12.20.2007, 01:11 AM
lol...2500watts...
yea...that is quite a bit to ask from some nylon...
glassdoctor
TEAM FUSION
glassdoctor's Avatar
12.20.2007, 02:11 AM
It shouldn't leak if you use gaskets. My 8ight has had the same Kyosho gear on it for over a year, and I have not had to touch it.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Happywing
12.20.2007, 08:56 AM
I've been using a Kyosho 46T spur for nearly a year too. It shows some wear, but it's still good. They are quite durable if the gear mesh is properly set.
