motor help
Talking motor help - 12.23.2007, 10:21 AM
Howdy all and happy holidays, 1st. time in the forum.http://www.rc-monster.com/forum/images/smilies/mdr.gif
brushless motor questions-
1.I converted my t-maxx to brushless and need a bigger motor that came w/ the mamba kit .... one that won' break the bank ...recomendations
2. how do I wire in a cooling fan for my speed controller to keep it happy
3. I am running 72/18 for gearing right now .... good , bad or can be better, recommendations?
4. I have noticed that some 1/8 scale guys are using Feigao motors, which would you recommend for my mbx-5 using the mm speed controller
Thanks for your advise.....GO FAST!!
aqwut
Brushless Heavy Weight....
aqwut's Avatar
12.23.2007, 11:17 AM
I have Brushless T-maxx.. my gearing is 22/60-66
I'm using a feigao 15L, powering off of 6S1P LiPo, and 8S1P LiPo.. .. it's very fast on 8S.. and Nitro speeds with 6S 2200mAh 20C... 6 or 8 A123 is very powerfull..
Welcome to the forums...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
12.23.2007, 12:04 PM
For your Tmaxx with an MM, I would say the 8xl is good for 12cells, or maybe the 9xl for 4s lipo. If your MM is an older model, it will support 14 cells with a little luck. See HERE for wiring diagrams, and HERE for gearing info; aim for about 35-40mph.
12.23.2007, 01:17 PM
THANKS FOR THE REPLY
1.WHERE DO i GET THE 1/8 BUGGY GEARS FOR MY T-MAXX AS WELL AS DIFF CASES
2.FROM THE PICS. ON YOUR WEB. THE TRUCK LOOKS SICK...HOW FAST?
3. FOR MY MBX-5 DOES THE NOVAK 4.5HV KIT SOUND GOOD?
12.23.2007, 02:40 PM
1. Turn your capslock off.
2. Mike is the only person who sells them-HERE. For cases, you can either use the FLM hybrids- HERE, or the UE Ultralite cases- HERE you will need two sets, and some 8x10x0.2 shims.
3. My truck? Sick it is, but fast it isnt. I'd say about 30mph tops with the Hvmaxx 6.5 I have. It will be alot faster once I get a new BL system next year...
4. If you already have the Hv4.5 for the buggy, then its well worth a try, but otherwise I would recommend reading around the forum for more ideas.
