All,
I have never used and do not own a Tap and Die set. However a post a little while back indicates that I need one :) At least a M3 for the FLM antena hole.
There has been other times that I wanted to do this also. So a little advice on where and what set to get would be great.
I would like to buy once and not have to buy again. Most of my uses are of smaller hobby stuff but sometimes grow into larger projects.
A nice case organizer would be good to. Also is there a handy guide that tells you which size drill bit to use before you use XX tap?
This seems pricy but sounds nice.
http://www.northerntool.com/webapp/w...70_34591_34591
However it does not list sizes.
Also it seams to me the Tap is the item of interest to me. It is always easy to buy a new bolt, but to thread a hole requires you have the tools, Am I missing something here?
Highflier
