Trinity Now
Jeremy1976
Trinity Now - 12.29.2007, 11:37 AM
You guys see this thing yet? It is suppose to be very well made and 40mph plus out of the box. 60mph plus with different pinion. Already comes with a 3s lipo and charger. Also a brushless motor. I am going to be picking one up in the next week.
This is the electric powered, radio contrlled, ready to run
1/16 scale Trinity Now Brushless Powered Truggy.
FEATURES: Chassis: .079" (2mm) thick aluminum construction (silver in color) Drive: Four wheel, shaft driven Motor: Trinity 280 size brushless Electronic Speed Control: Castle Creations Mamba 25 with Tamiya style battery connector, bullet connectors and on/off switch Radio: Pistol grip FM 27mhz with servo reverse, trims and steering dual rates (charge jack equipped) Battery: 11.1V 1350mAh 25C LiPo with tamiya plug and mini balancing plug (pack diamensions 4.1" x 1.32" x .87") Battery Charger: Balancing capable 2 and 3 cell Li-Po/Li-ion AC only Transmission: Equipped with metal gears Pinion Gear: 15 tooth metal construction Body: Prepainted and trimmed Wheels: White nylon 5-spoke - 1.42" (36mm) wide x 2" (52mm) diameter Wheel Hex Size: .33" (8.45mm) Tires: Off-road tread design - 1.4" (37mm) wide x 2.88" (73mm) o.d. Shocks: Oil-filled, nylon threaded body Camber: Adjustable, camber refers to the angle of the tops of the tires from vertical when viewed from front or behind vehicle Caster/Toe-in: Non-adjustable Steering: Bellcrank steering with adjustable rods
INCLUDES: Trinity Now Truggy with FM radio, 280 size brushless motor, LiPo battery, charger, Castle Creations speed control, instruction manual
REQUIRES: Eight AA batteries for transmitter and charging the included model battery with the included charger
SPECS: Truggy- Length: 10.5" (268mm) Width: 8.25" (209mm) Height: 4" (101mm) Wheelbase: 7.75" (197mm) Weight: Not Listed Body- Length: 10" (254mm) Width: 4.5" (114mm) Height: 3" (76mm)
rootar
rootar's Avatar
12.29.2007, 01:27 PM
lol........there is a 3 page long thread on the same page as this thread is in this section, look here http://www.rc-monster.com/forum/showthread.php?t=9118 its just right below this one we've been talking about them for awhile.
I ordered mine yesterday
Jeremy1976
12.29.2007, 03:01 PM
Sorry did not see it. Thanks for the link!
