UBEC/tapping from 4s w/balance tabs?
JeffEmbracedDC
JeffEmbracedDC's Avatar
UBEC/tapping from 4s w/balance tabs? - 12.31.2007, 02:11 AM
So, I could always use a UBEC...
Though, let's say I wanted a 7.4v output (at about 3amps) could I just tap directly off of the balancing tab? I understand that servos may not be rated for 7.4v, but that's beside the discussion. The question is just - can I pull 2S (7.4v) voltage (at 2-3amps) from the balancing tabs?
Thanks.
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
