Is This Normal?
NeuRevo
Brushless Revo
NeuRevo's Avatar
Is This Normal? - 01.08.2008, 08:01 PM
I have an E revo. Im runnin the neu 1515 1.5d, MM esc, and a Thunder power V2 25c 3850mah 4s lipo. I only get like 8 mins of run time. Is this normal. My temps are: motor 140, esc 100, batt 120, . And it coggs really bad when it at a dead stop till it starts to move then its fine. Im using the emax tranny with only 2nd gear in it.
I dont know if its my motor, esc, batt. Sumthin just dosent seam right. Im plannin on gettin a Quark and a 5s neu or Flight power Lipo. 5000mah or higher.
Thanks
83gt
01.08.2008, 08:35 PM
Are you using the voltage cutoff on the MM ? If so, can you check the voltage on the pack after the controller "says" it's done ?
phildogg
phildogg's Avatar
01.08.2008, 08:38 PM
well 3850 mah isn't alot..
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
jhautz
jhautz's Avatar
01.08.2008, 09:30 PM
The MM cogs with the Neu motors. Well documented fact. So bad in some cases that you toast the MM. Neu and MM are not a match made in heaven. Some have made it work thru conservative gearing and are willing to overlook the remaining startup issues, but for a smooth setup you should mate the Neu with another controller like the Quark or MGM.
As for the 8 minute runtime, a 3850 4s pack isnt that big. Vehicle weight, gearing, tire size and weight, and driving style all play into your runtime. So if you are looking to increase it look for weight you can drop or run a little shorter gearing. I have also found that a smooth throttle finger vs a heavy on/off nitro stlye throttle finger can really increase the runtime and also make you faster on the track. (At least for me it does)
The quick fix for both of your problems seems be to gear down a little. It will help with the startup cogging and increase your runtime but at the cost of some top speed.
to make it...
or break it...
Silent...But Deadly
