BL setup questions emaxx 3905
jediguru
BL setup questions emaxx 3905 - 01.11.2008, 05:22 PM
So I'm looking to convert my new emaxx 3905 to a single motor BL system. I was thinking about an 8XL or a 9XL running on a MM. Would this be a good setup? Initially I would run 14 nimh cells but am looking to run 4 lipo cells.
Would the MM handle that or should I go with something else?
Does anyone know what kind of speeds and run times I would get with either setup?
I'd like to be in the 40 to 45 mph range and at least 15 to 20 min run times.
Any input or experience would be much appreciated
Thanks
neweuser
neweuser's Avatar
01.11.2008, 06:23 PM
I think it would be a nice set up! MM would handle the batts no prob. I think there many here that run the same thing. But I doubt you would hit 45....but it seems to be dependable.
jediguru
01.11.2008, 06:57 PM
would I need to mod the MM? I thought it was only rated up to 3S and 12nimh.
01.12.2008, 06:12 PM
12nimh= 14.4v, 4s= 14.8v. The MM works fine on 4s, but you need to disable the built in BEC and use a UBEC or RX pack. Simply remove the red wire from the rx lead where it goes into the plug, and tape/shrinkwrap it back onto the cable. Other than that, you should be good to go.
