Truerc 12000mah 2s pack ?
speedy
Truerc 12000mah 2s pack ? - 01.13.2008, 10:19 AM
Hi !
Will a truerc 12000mah 2s pack fit into the 3905 e-maxx battery mounts ?
if i remove the stock plastic battery "straps" and run a singel motor setup with the motor mounted in the top motor mount and maby grind the lower edge of the motor mount ?
