Length of extended Stampede arms??
generalg
Length of extended Stampede arms?? - 01.18.2008, 02:48 PM
What is the length of the extended stamped arms both front/rear that FLM has?
Trying to compare/see if they are wider than a Jato front arm.
Thanks
01.18.2008, 02:52 PM
Extended Electric Arm Conversion
Made from aircraft quality aluminum for durability and strength.
CNC Machined for exact tolerances
Multiple shock mount locations
Front arms are extended with 2 different holes for extension (pin to pin 3.075 and 3.250 inches)
Rear arms are extended (pin to pin 4.000 inches)
Kit includes everything pictured along with hardware
FLM24900
generalg
01.18.2008, 03:15 PM
thanks!
A RC Dude
A RC Dude's Avatar
01.18.2008, 03:43 PM
so are thay the same or not?
Fast Lane
01.18.2008, 03:55 PM
We have several arms available.
Our newest extended front is 3.35 and 3.55 pin to pin. It is similar to the original just longer. To give you the same wheel width with the same offset wheel.
I am not sure on the Jato, so I cannot confirm their length.
generalg
01.18.2008, 07:17 PM
The Jato front arms are: Length: 4.45" (113mm
