Hi,
Well I'm using an OFNA extended chassis... Really love how this thing goes on 3s 5000/ 7L with the 2.8 annaconda's. 16/46 gearing
Differential Ratio: 3.25
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 16
Total Voltage: 11.1
Motor KV: 3511
Tire Diameter (inches): 3.75
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0059
Spur/Pinion Ratio: 2.88 : 1
Total Ratio: 9.34375 : 1
Tire Circumference (inches): 11.78 inches (299.24mm)
Total Motor Speed: 38972.1 RPM
Vehicle Speed: 46.53 MPH (74.75km/h)
Effective Speed Rate: 4.19mph/V (6.73kmh/V)
Effective KV Value: 3511
I've done some work on her this week in re-doing the esc mount, battery tray and fixing up the MM - extra 2700uf cap and 5.5mm motor connectors.
Also fixed the front body mounts with some traxxas ones...
For a treat I also put some new shoes on her tonight to get a bit more offroad traction - jato rear victory's all round...
The wiring only looks like a mess ATM as I have the eagletree installed with the esc temp and brushless rpm sensor.
I'll get some logs up over the w/e if the weather stays ok...
PS the body is my first non-one color wonder... so nothing special
