Originally posted by ulch
Thanks Maxxdude
I was posting at the same time you were so I missed your post.
What type of top speed and runtime will I get with the 7xl on 12 cells with standard gearing.
Also when will the 9920 be back in stock.?
Guys Im getting excited just thinking about it.
I would guess mid thirties on 12 cells and about 40 on 14 cells. But you will need to gear up a bit from stock to make use of the extra torque (this will help prevent wheelie's). You will also learn that first gear is a waste of time.
If those speeds seem a bit dissapointing, bear in mind that if/when you do decide to up the cell count to 16 or 18, the 7XL has the potential to touch 50 mph.
