would this motor be big enough ?
speedy
would this motor be big enough ? - 02.03.2008, 07:54 AM
Hi !
Will this motor http://www.himodel.com/electric/HiMo...e_5320-14.html be big enough to power a e-maxx 3905 without an gearbox ? I meen if i put the centerchafts direvctly on the motorchaft ?
Mod Man
02.03.2008, 09:18 AM
It should be a good choice judging by the listed specs. Should be enough power. The KV should be fine as well depending on how many cells you plan to run.
Matt
speedy
02.03.2008, 09:57 AM
i'm going to run with my mm-esc first on 4s but later i might try a mmm -esc on 6s.
mabe this one woud be better on 4s ? http://http://www.himodel.com/electr...ype_A4120.html
Serum
Serum's Avatar
02.03.2008, 10:23 AM
the last link doesn't work
speedy
02.04.2008, 11:44 AM
woud a eflite .60 size outrunner be enough ? it has 400kv and weights 380g and have an 6mm shaft so a output shaft from an emaxx gearbox choud fit :)
BL-Power
BL-Power's Avatar
02.04.2008, 11:46 AM
Yeah, it would be enough!
 Send a message via ICQ to BL-Power
02.04.2008, 12:22 PM
Hi !
Will this motor http://www.himodel.com/electric/HiMo...e_5320-14.html be big enough to power a e-maxx 3905 without an gearbox ? I mean if i put the centershafts direvctly on the motorshafts ?
woud a eflite .60 size outrunner be enough ? it has 400kv and weighs 380g and have an 6mm shaft so a output shaft from an emaxx gearbox should fit :)
just tryin to help.
