mamba 4600 on 4s or 6900 on 3s? which is faster?
mamba 4600 on 4s or 6900 on 3s? which is faster? - 02.04.2008, 11:40 AM
i decided i am going to go BL/lipo in my tc3 now. itll be a PURE speed machine. which of the 2 setups in the title will be faster?
BL-Power
BL-Power's Avatar
02.04.2008, 11:44 AM
4600rpm/V x 14,8V = 68080rpm
6900rpm/V x 11,1V = 76590rpm
=> The 6900 on 3S will spin faster.
 Send a message via ICQ to BL-Power
02.04.2008, 11:46 AM
Although the 4600/4s combo may tolerate higher gearing better since you're looking for high speeds only...
bdebde
That's All Folks!
bdebde's Avatar
02.04.2008, 11:48 AM
Both are over the max rpm of the motor, I would go with the higher voltage set up, may run a bit cooler.
02.04.2008, 12:18 PM
yeah, thats what i was thinking. thanks guys. ill have it ordered within the month.
snellemin
2 KiloWatt RACER
snellemin's Avatar
02.04.2008, 01:13 PM
Pick the lower kv motor and gear up. I only dragrace with 5000kV motors and below. The higher kv motors just draw too many amps, dropping the voltage too low, making reaching the topend harder.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
02.04.2008, 01:29 PM
Just a thought - why not a 5700 on 4s A123 as a compromise - I think this is what stampedeproject was running...
speedracer1129
02.04.2008, 11:55 PM
I am running a TC4 I just finished. 4600 on 4S with 25/75...74mph!! Motor and ESC temps at 100 or so!!! It is a good setup for playing around. Easy 20 minutes on Apogee 3800's. I dropped in a 5700 to see what it will do Wednesday night.......
Funny thing, I did this setup once before with a Cyclone and junked it because the 4600 on 4S would melt the diffs after 2-3 runs!! Few months later, I help someone setup a bone stock HPI Sprint 2 w/ a 7700 on 3S with 33/81 gearing and WHAM, 84mph on the radar!!!!! SOOOO, I am back again to prove a point!!
speedracer1129
02.07.2008, 08:22 AM
Just an update: 5700 on 4S, 32/69.........84mph!!! Slowly climbing
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
02.07.2008, 04:19 PM
Do you have to use the mamba motors? The novak 3.5r went 79 mph one year at the worlds fastest rc-car challenge on just 2s. Last year the HV4.5 went over 100 mph on 4s and 118 on 5s. These were just off the shelf setups too.
Area 52 Ranch Raceway
T.R.C.R.
snellemin
2 KiloWatt RACER
snellemin's Avatar
02.07.2008, 04:51 PM
I use to run 4s A123 with the 5700. It was silly fast, but heated up to quick.
Pedebeater
Pedebeater's Avatar
02.07.2008, 05:43 PM
You guys know that the 6900 should not be ran on 3s right? It is not made for that high of rpm, and will heat up very fast. Not a good idea imo.
Faster than a cheetah on cocaine
  Send a message via AIM to Pedebeater
Takedown
WARNING: May become violent.
Takedown's Avatar
02.07.2008, 09:30 PM
Like PB said. Not only will it be dangerous and void the warranty it will heat up very quickly. Castle motors tend to do that...
snellemin
2 KiloWatt RACER
snellemin's Avatar
02.07.2008, 09:56 PM
You forgot that you are on the RCM forum. The peeps here are brushless experts.
Takedown
Takedown's Avatar
02.07.2008, 10:07 PM
I guess... I still wouldnt use Castle motors if your going for all out insanity.
