06.02.2010, 04:55 PM
...You can see they are much longer than Neu leads, so I will probably shorten them....
Be careful doing that. If they truly are extensions of the coil wires, they will have an insulating varnish coating that will be almost impossible to solder. You will need to clean each strand and/or use some type of solvent to remove the varnish.
