simplechamp
simplechamp's Avatar
06.02.2010, 07:35 PM
Be careful doing that. If they truly are extensions of the coil wires, they will have an insulating varnish coating that will be almost impossible to solder. You will need to clean each strand and/or use some type of solvent to remove the varnish.
Right, that's why I was requesting some help or more info on how to do so:
Shortening the leads might be a chore, if you know a good way to remove the enamel coating from the winding leads post here or send me a PM.
