Originally Posted by BrianG
I'm not familiar with that conversion personally, but the Tekno conversions usually place the motor quite far back to allow room for the clutch. This has two disadvantages:
1: The motor is mounted directly to the chassis at a point away from the CD. When the chassis bends/flexes on jumps or whatever, the mesh may suffer causing premature pinion/spur wear.
2: Since the motor sits so far back from the CD, you need a long shank pinion to reach the spur. This can place a lot of stress on the motor shaft and bearings unless it is set perfectly. Also, this problem can be magnified during chassis flex as described in point 1.
Just to clarify, we supply an additional brace to prevent any flex around the spur/clutchbell/pinion area. We never here or see any issues about flex in our kits.
You do however need to run a long shank pinion if you want to run direct drive. This is so you can also use mechanical brakes more easily. All options are available if you're not digging the clutch.
