Good shocks?
Urgeoner
Urgeoner's Avatar
Good shocks? - 08.01.2009, 08:35 PM
I keep striiping my rear shocks.
Any good aftermarket ones for the Revo?
brushlessboy16
brushlessboy16's Avatar
08.01.2009, 08:41 PM
define stripping of shocks. could mean alot of things
Urgeoner
Urgeoner's Avatar
08.01.2009, 10:47 PM
The threaded parts that connect to the plastic ends keep stripping. Are there aluminum shock ends that we can buy?
Snipin_Willy
Snipin_Willy's Avatar
08.01.2009, 11:31 PM
Something is wrong if you're stripping the shock ends off the rods.
brushlessboy16
08.01.2009, 11:33 PM
Are you running a rear sway bar
Semi Pro
Semi Pro's Avatar
08.02.2009, 12:10 AM
the best shocks you can buy are the aluminum GTR bodies
are you ripping the caps off? sounds like you have striped threads
08.02.2009, 12:18 AM
Back when I had a converted Revo, I noticed that if the rear end was too soft, the shocks would bottom out easily on jumps. This puts a lot of strain on the shock ends.
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
08.02.2009, 01:27 AM
yeah something has gotta be wrong.
if you put ANTI strain on the suspension...like land a large jump dirty side up hard on one wheel it will tend to pull either the shock end or the push rod ends off.
mostly my rod ends have been stretched so i just replaced mine today.
yes you can buy ally ones but make sure it isn't something more that is causing the problem.
  Send a message via MSN to shaunjohnson
Finnster
KillaHurtz
Finnster's Avatar
08.02.2009, 01:32 AM
These are decent. Rod ends can rip off on jumps/ hvy springs or crashes as there are no downtravel limiters on the Revo, and the shock ends take it. Had a problem a few years ago and these took care of it. Bit of a pain to get in tho.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.02.2009, 11:04 AM
In the picture off the link whats the bronze colored washers for ? or are they bump stops ?
Urgeoner
Urgeoner's Avatar
08.02.2009, 06:16 PM
Okay thanks. I'll buy these ASAP. I am not using a swaybar, but should I?
brushlessboy16
08.02.2009, 06:32 PM
no, the rear sway bar is what caused mine to fail
Finnster
KillaHurtz
Finnster's Avatar
08.03.2009, 08:57 PM
There are tiny bearings in the shock end and the brass things are bushings to act as spacers to fit in the rocker arms properly. My bearings eventually failed after a couple years, so I used a vice to press some 3mm spacers into the hole, and just ditch the bushings. They were the spacers included w/ the tie rods for the bearing carriers for bumpstop adjustments. I only ever used one setting (the tall hollow ball) and put the spacers to use.
