MMM V3 - First Run Opinions
JaySki
JaySki's Avatar
MMM V3 - First Run Opinions - 10.22.2008, 06:36 PM
So.. I know I ran it a bit last night, but today.. I grabbed a pack of MaxAmps 2X 2S2P 8K and my Zippy H - 2X 3S1P 5000 and went to the big back parking lot behind the shopping center around here.
On 4S - Temps never broke 45 on the 1Y and maybe 50 on the MMM, granted, it's only 50 outside maybe, but I am impressed.
Geared 22/56 I hit 43.8MPH. The Eagle Tree says I hit a max Amp Draw of 114.77 Amps(A little higher than I expected to see) MAx RPM was 34,403. About where I would have expected. Nice set up for mid 40 runs and solid performance.
Decided to press my luck and ran 6S. Temps still stayed pretty darn good. Motor ran about 60 degrees, The MMM had to have hit 150ish as I heard the fan run briefly. Even after a solid pass and temp reading, the MMM read about 80. Now.. This thing on 6S... is absolutely SICK! I managed to hit 59.8MPH and probably could have hit over 60, however I ran into to problems... I would run out of parking lot trying to open up the throttle, or I would left the front end over and end up on the roof trying to get to full speed a bit faster. I swear.. I had to be in the 40-50 range and if I opened the trottle up all the way, it would still lift the front end up and over. I had quite a few runs of watching the revo slide across the asphalt on it's roof doing 40+. Needless to say my etrex Summit GPS now has some nice road rash. :)
Max Amp Draw on 6S was 125.59 Amps Motor hit 49K RPM (Not going to do that often!) High Watts was 2455 and mAh used came in at 4370 between the 2 packs.
The V3 performed FLAWLESSLY and seems like it is going to be pretty rock solid. I look forward to seeing how it does long term.
SunnyHouTX
SunnyHouTX's Avatar
10.22.2008, 06:52 PM
Nice! Very good report man. Thanks.
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
10.22.2008, 07:02 PM
That is SO good to hear! Sounds like Castle have finally cracked it.
transtalon
10.22.2008, 08:33 PM
What was your motor on the revo?
JaySki
JaySki's Avatar
10.22.2008, 09:03 PM
NEU 1515 1Y
Killa - Will do.
SteGra
10.23.2008, 04:51 PM
Originally Posted by JaySki View Post
NEU 1515 1Y
Killa - Will do.
Nice report and good to hear the MMM v3 is worth the wait.
It sounds like your set-up is exactly the same as the new brushless e-revo (MMM v3 Neu 2200).
Was your MMM programmed differently than stock?
A parking lot is great for some high speed runs, but hate to see the rollover damage.
JaySki
JaySki's Avatar
10.23.2008, 06:25 PM
yea.. the roof of the original body is now a moonroof. Also wore the front body mounts down to nothing. Had to replace those as well.
killajb
killajb's Avatar
10.22.2008, 08:42 PM
JaySki,
I'll be in the Detroit area (near Metro Airport, Romulus) from Sunday-Friday of next week. I'll probably bring a vehicle with me to goof around with. PM me if you wanna have a bash session and let me know what type of rig I'd need. (I have a ton of cars btw..)
e-mike
e-mike's Avatar
10.22.2008, 10:08 PM
wowowthe best thing i read this month!!!!!i receive a other e-mail from cc todaynow im less scared
thanks for the review!!!!
D8t on juice!!
david lamontagn
10.22.2008, 10:17 PM
now im less scared
Me too
teknorc
10.23.2008, 01:34 AM
I just updated an MMM V2 I had and it ran great for an hour of running so far. Previous MMM's in our setups were dropping, so this is excellent. Thanks Castle!!
Tekno RC - Performance Parts
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
10.23.2008, 07:00 AM
Was hoping to try out my V1 with the new firmware tomorrow but by the looks of it I will be working on the 1:1 scale car
lxmuff
lxmuff's Avatar
10.23.2008, 08:08 AM
Why don't you get out and race that thing locally? There are a lot of MT drivers and some other electric ones too around here..
JaySki
JaySki's Avatar
10.23.2008, 09:09 AM
Where?
lxmuff
lxmuff's Avatar
10.23.2008, 10:12 AM
Where?
They hang out here.
http://bannedrc.com/forum3/viewtopic.php?f=42&t=11098
Happywing on this forum races with them too.
