tires for BL emaxx -
02.14.2008, 11:47 AM
Just wanting some opinions on some good tires to run on my BL emaxx3905. I had the talon tires on it and they just balloon too much. Its hard to control. Has anyone had any luck with other tires? Or has anyone tried strapping the inside of the tire with strapping tape or some other tape? Did it help?
Thanks for any input guys.
02.14.2008, 12:14 PM
im running the stock emaxx tires right now and they do not balloon,im running brushless too,but i really dont like the way they look,so this thred should help me too
02.14.2008, 12:17 PM
putting a layer of duct tape on the inside of the tire helps the ballooning alot. I have been running the losi zombimaxx tires with the duct tape and really like them.
to make it...
or break it...
Silent...But Deadly
02.14.2008, 01:42 PM
Bowtie MTR's are nice, no need for tape. :) Tread wears quickly though. I also have a set of Zombie's, balloon all to beat hell (with no tape), so bad infact, I have no control. Trying a set of the Badlands next, not sure with or with out tape though. Taping for me is hard, tried it once and it deformed my tire, so not sure if I did it right. Any tips on that would help others as well.
02.14.2008, 05:00 PM
i use truggy tires with a dence foam, and they have small holes punched in them along the center of the tread. they're grp's.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
02.14.2008, 05:06 PM
Using the Ofna Med foams work nice too. They last longer than the tire!
02.14.2008, 07:19 PM
I've also done the duct tape trick on the inside. Works great!
02.14.2008, 07:20 PM
Any tips?????
I like chocolate milk
02.18.2008, 09:46 PM
Originally Posted by neweuser
Any tips?????
Well, I just flip the tire inside out, and then measure off (by rolling) how much tape I need. I cut a piece to that length, lay it sticky side up (duh!) on a flat surface. I get the tire aligned with the tape, and slowly roll it down the tape. I aim for about a 1/2" overlap of tape at the end, to not throw the tire off balance (although I admit the bigger tires are less sensitive.) After it's all on, I just roll it back and forth on the same hard surface to make sure everything is bonded. Flip the tire back and there ya go, perfect tire. I've never really deformed a tire doing it this way. Maybe I'm special?  Kinda doubt it!
02.18.2008, 11:14 PM
Special in a cookie kind of way
02.14.2008, 07:36 PM
I tried to tape some tires once and after 1 run the tape broke loose.
phil
02.14.2008, 11:31 PM
phil
You gotta clean the inside of the tire before applying the tape or it wont stick very well to the inside. The tires tend to be coated in mold release from when they were made and nothing sticks well to it. Thats why you need to clean the tire beads before gluing them also.
to make it...
or break it...
Silent...But Deadly
02.15.2008, 12:33 AM
I'm looking for a more all round use tire. Bowties and crimefighters are gone in a blink of an eye on pavement. Any ideas?
Taping badlands, is it needed? -
02.15.2008, 10:11 AM
The badlands seem to be a good all around tire dude. I just bought a set last week, and they are beefy. Sjcrss can contest to that as well.
On a side note, the only thing about them that I don't know is if they balloon badly. Anyone know if they need to be taped or not? I had no need to tape my MTR's at all. But not sure about the badlands....
02.16.2008, 12:17 AM
i washed and scuffed the inside before using the gorilla tape. been running the Proline crimefighters for months and no ballooning. works like a charm. only problem is that the crimefighters, like mentioned above, is pathetic on pavement. all the tread is basically gone only after a couple of months.
i too am thinking of another set. i love the traxxas talons i had on before, but the sidewalls just couldn't hold up to 8xl on 5s. started tearing at the beads. was thinking of going with 40 series road rage or proline mashers. anyone has experience with these?
