1717 Possible to snap motor shaft from too large pinion?
Revorocks
1717 Possible to snap motor shaft from too large pinion? -
01.14.2012, 06:02 PM
Hi there,
I'm doing a Hyper 7 speed project and will be running a pretty large pinion.
Is it possible to snap motor shafts from running too large pinions?
I'm running a Neu 1717 with 5mm shaft.
Will be running a 26T or 32T pinion.
E-Revo Brushless MMM + Neu 1515 5S
Hyper 7e MMM + Neu 1717 6S Speed Project
Revorocks
Find all posts by Revorocks
2
01.14.2012, 07:15 PM
5mm shafts rarely break.
Side loads on the shaft normally cause bearing failure.
High RPM's will cause magnets to crack..
Find all posts by Arct1k
3
anunaki
01.16.2012, 11:18 PM
Can you explain what a side load is in detail.
anunaki
4
01.17.2012, 11:05 AM
anunaki
If you set the spur/pinion mesh too tight, the shaft tends to "push" against the shaft bearing (especially the front one). Therefore, a constant load on a bearing spinning that fast can cause premature wear.
Visit BrianG's homepage!
Find all posts by BrianG
5
Revorocks
01.14.2012, 09:16 PM
Ah ok, that's good to know.
I wouldn't have thought it was possible for the motor to sheer the shaft from sheer torque, but I just wanted to be sure.
Thanks
Revorocks
Hybrid Mode
Switch to Threaded Mode
Off
