1717 Possible to snap motor shaft from too large pinion?
anunaki
01.16.2012, 11:18 PM
Originally Posted by
5mm shafts rarely break.
Side loads on the shaft normally cause bearing failure.
High RPM's will cause magnets to crack..
Can you explain what a side load is in detail.
anunaki
2
01.17.2012, 11:05 AM
anunaki
If you set the spur/pinion mesh too tight, the shaft tends to "push" against the shaft bearing (especially the front one). Therefore, a constant load on a bearing spinning that fast can cause premature wear.
Visit BrianG's homepage!
Find all posts by BrianG
Hybrid Mode
Switch to Threaded Mode
Off
