MGM 22418 & 6S LiPo is No GOOD
aalzuhair
MGM 22418 & 6S LiPo is No GOOD - 01.01.2008, 04:38 PM
I posted this in another thread, but then I thought it might be better to start a new thread about this …
I just got two 22418 MGM's (one for me and one for a buddy) and both were to be in 1/8 buggy using a Neu 1515/1.5D ... anyway, on 3s Lipo it was doing fine .. but when on 6s .... white smoke and that sweet smell of burning electronics ... So, I thought it could be the brand spanking new Neu motor so I used another motor that works just fine with a Quark 125 Monster Pro..... long story short ... both are fried now :( .. ohh yeah and that was over about a WHOLE 3min of using the ESC ....
Does anybody else have or had the same problem with this ESC? … And how is MGM customer service?
Anyway, I e-mailed them about the problem and waiting for their response …
Oh, God I wasted so much money on making a new 1/8 chassis purely for a brushless setup and I was betting on the 22418 that it would handle the 6s LiPo and work nicely on a 1/8 … I will keep you guys posted on the outcome?
Az
aalzuhair
01.01.2008, 04:42 PM
Ohh, just in case ... I will not stop my project I'm currently just waiting on Mike to give a price on a part that I have request ... The show must go on hehehe
david lamontagn
01.01.2008, 04:50 PM
Realy hope that my 16018 will hold up my 4s li-po and 5s2p A123, Neu 1515 1Y on my e-revo
As i said in another post, pay alot of $$$ for controller don't give guaranti that's a good controller.
knotted
01.01.2008, 06:49 PM
Been using my 22418 with 6S Flightpowers and a Neu 1521 for over 2 months now with no problems. The guy I run with has a 16018 with 6S Neupower batteries and a 1515. He beats the heck out of it and no smoke. I hope this isn't a bad batch as I was getting ready to order another one. Keep us informed, please!
aalzuhair
01.01.2008, 07:04 PM
I was really looking forward to using the 22418 with the 1515/1.5D .. :) Well I hope they can fix whatever it is and fast
ssspconcepts
ssspconcepts's Avatar
01.01.2008, 11:32 PM
I run a MGM22418 with 5S flightpowers, 1515 1.5D/F, and 18/46 gearing in my Jammin CRT. All I see is a hint of cogging if I mash on the throttle (I can fix this by gearing differently). Temps are super cool.
I also have another MGM22418 that I run with 6S flightpowers, 1515 2.5D/F, 16/51 gearing in a HEAVY all aluminum Emaxx (big honkin MT beadlock tires & rims too). Zero cogging and temps are well within acceptable limits-quite cool actually.
I have not experienced-knock on wood-any problems with these ESCs...I think there has to be other issues that caused your problem.
aalzuhair
01.02.2008, 04:27 AM
Good to hear :) It just might be that those two had something wrong with them.
aalzuhair
01.02.2008, 04:47 AM
Here is the settings that were on both.
The burned_one pic was the first one that worked for about 1 min before it burned. That was on 1515/1.5D and two MaxAmps 5000mah 11.1v
The other_one pic worked on another motor (XLT-1 Nemesis) motor using one 5000mah 11.1v LiPo and then two LiPo's (22.2v) and the rest is history
ID:	3695   Click image for larger version
ssspconcepts
01.02.2008, 07:26 PM
What was your gearing...and was you gear mesh okay? I keep my gear mesh a little farther apart than some folks...just a hair. But it helps the gears spin with less resistance. Not trying to insult your intelligence but I once saw a guy that had the motor pinion pressed up against the spur so hard that the car would barely move! That would definitely put some strain on the motor and ESC. I'll get some screen shots of my MGM settings in the next day or so and post them...but in all honesty, I didn't really adjust too much...I think just the battery and brake.
ncalenda
Need for Speed
ncalenda's Avatar
01.02.2008, 02:43 AM
I had my 16018 go the same way, I sent it back for repair, no word yet.
  Send a message via AIM to ncalenda
aalzuhair
01.02.2008, 04:36 AM
ohhh, by the way ssspconcepts Would you like to share the settings of the 22418 on the Jammin CRT?
Thanks,
Az
ssspconcepts
01.04.2008, 08:33 PM
Thanks,
Az
Hey Wildman,
My settings are the default settings, except I switched to 5 Lipo for the battery setting. I will tell you this...unbeknownst to me...when I plugged into the USB interface, the software automatically returned my controller to default settings...to include setting it back to 2-pole motor mode. This took me about an hour to figure out why the controller wouldn't work after I checked my settings. I went thru the initial setup about four or five times and the controller would just sit there and beep. Well, I went back to the USB and noticed that it was in 2-pole motor mode-bingo. I set it back to 4-pole mode (for Neu motors are 4-pole motors) and went back thru the setup procedure and everything works fine now--whew!!!!!! Quite a scare I had there. You can see the video of my maiden run if you goto my picasa link http://picasaweb.google.com/ssspconc...36201234213570
aalzuhair
01.05.2008, 03:14 AM
UPDATE:
After I e-mailed Martin, I got a call back from him (That was nice) and he said no matter what the case is, they will fix it ... and that it will not take too long to do so.
He will be needing the ESC and the motor being used, which I will FedEx to him ASAP.
ohh, and if the problem is from the ESC and not the setup they will fix it at no additional cost (under warranty) ...
The good thing is that $800 will not be a total waste and the fact that they want to see the ESC and motor, indicates that even if the problem is form the ESC, they want to understand why!
I will keep you guys posted.
Az
EDIT: SO far MGM Compro customer service is an A rated
ssspconcepts
01.05.2008, 11:36 AM
UPDATE:
Az
If it is the controller...Are they going to take care of the motor too?
aalzuhair
01.05.2008, 11:44 AM
What do you mean? take care of the motor too ... like kill it ...hehehehe
No, seriously what do you mean?
