pinion for 6mm kb motor aksels
ghostriderlund
speedfreak.dk
pinion for 6mm kb motor aksels - 01.15.2008, 08:30 AM
hello there.
i want to throw a kb inrunner 2300kv on a sportswerks mayhem truggy, only thing missing right now is pinions for 6mm kb aksel.. any suggestions on where to get those ?
i got som 5mm pitch 32 pinions but its hardened steel from plettenberg so not sure if they can be drilled..
what have those of you who drive kb 6mm aksels done?
hope to hear some good advices from you guys :)
best regards from denmark
BL-Power
BL-Power's Avatar
01.15.2008, 08:57 AM
In this thread you can find some information where to buy 6mm pinons:
http://www.rc-monster.com/forum/showthread.php?t=7642
You could also turn down the shaft to 5mm, then you would be able to use the pinions you already own.
 Send a message via ICQ to BL-Power
ghostriderlund
speedfreak.dk
01.15.2008, 09:08 AM
thanks BL-Power..
why didnt i think of that :D i have done it before with 2,3mm to 2mm for 1:18 cars. i think i will go that route this time also. thanks for quick help
bye
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
01.15.2008, 11:26 PM
Is the bolt pattern on these motors the same as normal 540 motors?
01.15.2008, 11:35 PM
No, the kb has a 30mm pattern, nit the usually 25mm. Plus it has m4 threads, not the m3 in a std 540. I make my own motor mounts most of the time, so it is not a big deal for me.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
01.16.2008, 12:03 AM
I want to use it with the savage conversion and it would be a shame not to use that beautiful motor mount.
Thanks lincpimp you seem to be answering all my questions today.
01.16.2008, 12:08 AM
No problem, I am sure that mike can whip you up a motor mount to handle the kb 45. I may use my kb45 8l in my savage conversion, (just bought mikes chassis and a ss kit) and I will make my own front mount. Mike's chassis sure is nice.
I am only able to answer them all as you are asking about things I know. Ask a question about a neu motor and I will be quiet!
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
01.16.2008, 12:12 AM
I'd have to be able to afford one first .
01.16.2008, 12:54 AM
Right there with you. I have issues buying a 300 dollar motor. I have spent some money on this hobby. I usually try to find hacker motors for sale. They have plenty of power and work wel with a MM. Most of the time they can be had for around 100 bucks. I will also say that the cheaper (feigao, KB) motors work much better with over 5s lipo. I have an emaxx with a feigao 15l (1600kv) on 5s and it runs fine, with great temps and tons of power. I have a feeling that the lower qaulity is more of an issue at higher amp draws, as seen with the higher kv motors.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
01.16.2008, 01:02 AM
The price to performance ratio is a bit high with the current neu motors, I think. I still want one but I probably will never get one. The MMM version sounds more affordable and the ratio will probably be a lot better if it ever comes out.
