MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
01.16.2008, 12:03 AM
No, the kb has a 30mm pattern, nit the usually 25mm. Plus it has m4 threads, not the m3 in a std 540. I make my own motor mounts most of the time, so it is not a big deal for me.
I want to use it with the savage conversion and it would be a shame not to use that beautiful motor mount.
Thanks lincpimp you seem to be answering all my questions today.
01.16.2008, 12:08 AM
No problem, I am sure that mike can whip you up a motor mount to handle the kb 45. I may use my kb45 8l in my savage conversion, (just bought mikes chassis and a ss kit) and I will make my own front mount. Mike's chassis sure is nice.
I am only able to answer them all as you are asking about things I know. Ask a question about a neu motor and I will be quiet!
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
01.16.2008, 12:12 AM
I'd have to be able to afford one first .
01.16.2008, 12:54 AM
Right there with you. I have issues buying a 300 dollar motor. I have spent some money on this hobby. I usually try to find hacker motors for sale. They have plenty of power and work wel with a MM. Most of the time they can be had for around 100 bucks. I will also say that the cheaper (feigao, KB) motors work much better with over 5s lipo. I have an emaxx with a feigao 15l (1600kv) on 5s and it runs fine, with great temps and tons of power. I have a feeling that the lower qaulity is more of an issue at higher amp draws, as seen with the higher kv motors.
