Wired Backwards?
JOEX
Wired Backwards? - 07.06.2008, 12:02 AM
I made a boo boo...
Added some connectors to the a123 batteries I got from kulangflow so I can use the series adapter I made awhile ago but I put them on backwards
Will this still work?
Name:	series wiring check 003s.jpg
azjc
07.06.2008, 12:08 AM
you need to wire them correctly or your batteries will be no more
VintageMA
VintageMA's Avatar
07.06.2008, 12:10 AM
I would say redo the connectors or re-wire the y adapter.
If you hook it up the way it currently is, you will be connecting + to - and - to + and you'll probably let your smoke out in a bad way.
“Everyone has a right to be stupid; some people just abuse the privilege.”
JOEX
07.06.2008, 12:13 AM
That's what I thought... I need more soldering practice anyway
Thanks
Sammus
Sammus's Avatar
07.06.2008, 12:15 AM
FWIW when my sidewinder esc first came a little while ago I accidently soldered my deans on backwards, I hooked it up, no go. I freaked out, unplugged, resoldered backwards again (This was not one of my better days ) repeat, then got it the right way. the esc and batts were fine
speaking of brain farts
azjc
speaking of brain farts - 07.06.2008, 12:23 AM
I was in the process of disabling the on board BEC on my Mamba 25 for my RC18 and use an extra CC BEC I had... I programmed the BEC and wired everything up than when it came to pulling the red wire you can guess which red wire I pulled.....than everyone was out of the BECs but the truck needs the diffs rebuilt anyways...so it continues to sit
JOEX
07.06.2008, 12:36 AM
I'm a little slow....... Just pulled the terminals out and switched them around, no resoldering.
This look better?
Name:	series wiring check 004s.jpg
Sammus
Sammus's Avatar
07.06.2008, 12:48 AM
pulled the terminals out? is that some fancy thing you can do with traxxas connectors?
07.06.2008, 02:40 AM
Yep, they will fit on either side. You cannot use the male terminal in a female plug casing though, as they are different.
