Sammus
Sammus's Avatar
07.06.2008, 12:15 AM
FWIW when my sidewinder esc first came a little while ago I accidently soldered my deans on backwards, I hooked it up, no go. I freaked out, unplugged, resoldered backwards again (This was not one of my better days ) repeat, then got it the right way. the esc and batts were fine
speaking of brain farts
azjc
speaking of brain farts - 07.06.2008, 12:23 AM
I was in the process of disabling the on board BEC on my Mamba 25 for my RC18 and use an extra CC BEC I had... I programmed the BEC and wired everything up than when it came to pulling the red wire you can guess which red wire I pulled.....than everyone was out of the BECs but the truck needs the diffs rebuilt anyways...so it continues to sit
JOEX
07.06.2008, 12:36 AM
I'm a little slow....... Just pulled the terminals out and switched them around, no resoldering.
This look better?
Name:	series wiring check 004s.jpg
