TroubleMan
05.15.2011, 11:31 PM
The bearing size is 10x6x12mm for these cars i looked for a while for a bushing this size with no luck and then i was forced to make them but now i have options so tomorrow ill have some bushings made. I will be thread locking the bushings then drilling then tapping and ending with a grub to lock the wheels.
Name:	2011-05-15 19.02.33.jpg
ID:	9954   Click image for larger version
Name:	2011-05-15 19.02.01.jpg
ID:	9955   Click image for larger version
Name:	2011-05-15 18.46.12_Detroit_Michigan_US.jpg
x-y
x-y's Avatar
05.16.2011, 05:49 AM
Originally Posted by TroubleMan View Post
this was some rush work when i first built the cars but now i have cnc mill access the motor mount will be replaced this week for the up and coming season. the other car is a XR80 he's now running 8s with mech brake . i have a small crack from a collision that happend last year in my front bulk so... since i don't have my bearings done yet i could post the process i use here.
I recommend you protect the lipos with a aluminum plate or a hard plastic ....... if you have a bad crash is possible have a disaster :p
http://www.youtube.com/watch?v=awOIy...layer_embedded
SWORKZ BE-1, LEOPARD, HOBBYWING, GENS ACE, SANWA VX, FUTABA 3PL, MBX5R/T, RB5SPSL, FG MONSTER, TC5R, 808E, HYPER8, TF5, ZX5, NANO-TECH, HYPERION, 620DMG, ECO6-10, TEAM-IHOBBIES
TroubleMan
05.16.2011, 12:21 PM
With this kind of car it's like riding a motorcycle it's risky,dangerous, but i fully understand what i'm doin and i wish lipo were not so dangerous but no pain no gain !
superek4
superek4's Avatar
05.21.2011, 06:02 AM
What gearing you guys do? Rc monster has a 46 spur for gt cars. I will use either a 2250kv motor or 2700kv motor. Wat pinion u guys recommend?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
superek4
superek4's Avatar
What bearings are these?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
BIG-block
05.22.2011, 02:42 AM
Is one of those motors in the last pic much fatter than the other or is it just my eyes playing tricks on me?????
You ask and you shall receive...Although it's a MRX-3...same basic set up. It's a Revo motor mount
I had a machinist press a fitting inside the hub which in turn eliminated the one way bearing and allows me reverse and motor bakes. Eventually I am going to eliminate the AL bottom battery brace and replace it with carbon fiber...
I am running a 1800kv on 6s and it flies...haven't quite dialed in the esc for a little drag brake, motor brakes yet but working on it. The first time I took it out I almost totaled the car..missed a concrete light stanchion by inches doing 50mph+ This is my first true on road car as it has a learning curve as I only have been running in the dirt
Thanks for that pics guys. This is going to help immensely with my Serpent 960 conversion I think I am going to do the batteries the same way as you did magman. I hope I can get some 4-5mm thick carbon fiber plate and make like a wide pan chassis so that the batteries can fit on the sides of the chassis. I think that would be the neatest and easiest solution (posibly the lightest as well). Do you guys think that 5mm thick carbon fiber would be ok for the main chassis (bare in mind it will be a lot wider and hold the lipos on the sides)???? Once again thanks the pictures. Great help.
superek4
superek4's Avatar
05.22.2011, 06:35 AM
Rcm make a 1 speed spur for 6mm shaft. I am getting that for my mrx2
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
Overdriven
Destroyer of Tires
Overdriven's Avatar
05.22.2011, 11:01 PM
Magman is running a CC1512 1800kv. The shorter can size in a small space does play tricks on your eyes a bit.
BIG-block
05.23.2011, 05:06 AM
Link please!!!!!!
Also If and I mean If I decide to keep it as a two speed what are the gears I need to get. I an totally a noob when it comes to this kind of two speed setup. I think I will get one either way just to try and see. I might like the two speed but I just like the simplicity of running just one pinion and one spur gear. Less moving parts the more I like it.
I am going to make up a mount that I think will even house a 1518 (from what I can measure it should). I am not sure if I'll use the 1518 on it but if I do it will have to be on 8S. That will mean a plane ESC (to keep the costs down) and will need to run mech. brakes (I think I have even this figured out).
What is troubling me now is the absence of front braking. Actually scares the crap out of me. I really want to run front brakes but that means locking up the font axle. How would this make the car handle? I wont be racing it as I just want something fast and fun but don't want something that corners like a drunk pig. Wish that there was a front diff option.
BIG-block
05.23.2011, 05:11 AM
OK, that's what I was thinking. The next motor in size up (diameter wise) is the 1717 and that would be just plain crazy in one of these things.
superek4
superek4's Avatar
05.23.2011, 06:15 AM
http://www.rc-monster.com/proddetail...=RCM6mmsnglspd
Hope it helps
Link please!!!!!!
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
BIG-block
05.23.2011, 06:20 AM
I think I will be able to make that work easily. Just not sure about the spur size. Worried it might be too small. I want the option of running the mechanical brakes so not sure how big of a pinion I would have to run to get the gears to mesh and motor to clear the brake disc. Will have to do some more measuring. Thanks for the link superek4. Everything helps.
superek4
superek4's Avatar
05.23.2011, 09:02 AM
No problem
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
Overdriven
Destroyer of Tires
Overdriven's Avatar
05.23.2011, 08:03 PM
Unfortunately the pair of one way bearings seem to be the front diff. Personally I'd rather have the 4 wheel braking, so I'd set it up that way and see what happens. It might turn pretty good, and shifting more weight up front will help the car turn better too.
superek4
superek4's Avatar
05.23.2011, 08:06 PM
Is motor brake not good enough?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
