Pdelcast
Pdelcast's Avatar
05.24.2008, 01:27 AM
Patrick, help me understand one thing. You have mentioned the the hardware from the controllers mentioned above are not compatible with the Mamba software right? Please explain to me in terms that a non engineer guy can understand? I see other companies transform their aircraft controllers into car controllers and I would love to get my HV110 and possibly a SHV with a car software, not the Mamba, but something simple that would allow me to use a pistol radio and be able to use a car brake as I don't have many cars with mechanical brakes. I always thought it was just as simple as changing the software.
Well, it's the hardware on the control board that isn't compatible with the car software.
I designed the airplane controllers before the car controllers, and the car controller have some SERIOUS advancements over the airplane controllers in the sensitivity of the back-EMF circuit. (there is a patent on it too -- just got finalized.) http://www.freepatentsonline.com/y2007/0029956.html
So the car software just won't work on the airplane hardware -- different type of back-EMF sensing.
To run car software on the airplane power boards, I'd have to design a new control board for them.
But airplane power boards are really designed for airplanes - - not for the types of loads that cars put on a controller -- our car controllers ALSO use very heavy copper (6/6 on the MM, 6/6 + 4/3 on the MMM) but are designed to handle short term overload currents better than the airplane controllers. The MMM has the same number of FETs as the Phx-80, but handles over double the surge current and over double the continuous current. Part of that difference is the fan/heatsink, but the majority is the copper layout and current path copper total. The Phx-80 was designed to be light weight and compact, the MMM was designed to handle serious current surge and power.
Patrick del Castillo
President, Principle Engineer
