lutach
lutach's Avatar
07.01.2008, 09:46 AM
Originally Posted by DiFabio42 View Post
Sup Guys?
1. When I convert my CRT to Brushless. Can I run it all the way till the batteries die? Or is that not safe? Are you not supposed to drain it lower than 3.7v? Can someone help me?
2. What other stuff should I know about Lipos?
3. How much runtime will I get on a TrueRC 6s 8000mAh Lipo?
4. Anything else I should know before I convert it so I don't blow up the house or anything?
Thanks, Austin.
1. I set me LVC to 3V, some play it safe and go a little higher to 3.1, 3.2, 3.4 or what ever setting your controller allows you to set. You will kill your pack if you go until they die. One rule is: If your vehicle is showing signs of slowing down, stop, let the pack cool and charge it.
2. Don't abuse them. Human mistakes are the leading cause of almost all the shit that happened with lipos so far.
3. It will depends on your set up. Your gearing will be the major contributor of how long you will be able to run. I have my vehicles set to about 30mph+ right now and I get bored after 20 minutes.
4. Don't be too hard on your nitro buddies. They won't know what hit them after they only see dust . The best thing to know is, have fun .
Not much info, but I try my best.
