DiFabio42
07.01.2008, 09:58 AM
I'm going to get the MMM ESC.
Can I charge the Lipo at 10 Amps? Whats 1c mean?
lutach
lutach's Avatar
07.01.2008, 10:05 AM
The MMM has a setting that allows you to set the LVC. Your 8000mAh pack should be charging at 8 amps which equals to 1C.
DiFabio42
07.01.2008, 10:13 AM
Oh, Alright. Does the Hyperion EOS0610i automatically do that?
lutach
lutach's Avatar
07.01.2008, 10:17 AM
I use an Astro Flight 109 and I have to manually set the AMPs. You can set the Hyperion manually as well or save a setting so you can use it later. I'm not sure if the Hyperion will charge 6S at 8A. My AF109 is automatic and the higher the cell count the lower the AMPs it charges them.
DiFabio42
07.01.2008, 10:29 AM
http://www.impaktrc.com/product_info...oducts_id=2058
It says 250 Watts Max Output even on 6s.
