lutach
lutach's Avatar
11.24.2008, 09:34 PM
Originally Posted by jordan... View Post
Ahh i see, I'm thinking about how to make one, hopefully i can find a friend who has access to a CNC machine Even with overloading the ESC, shouldn't it still have been fast? Im going to try and tweak some things here and there. How does the motor timing work? I have it auto at the moment but im not sure what changes will do?
Not on grass. You're luccky none of the FETs blew due to the high stress you put on them. You have to find a way to use at least a 51T spur with a 11T pinion to run on 5S or you have to use 3S lipos. Auto timing is fine or 0 degrees as you have the D wound Neu motors. One thing good about the MGM is that the ESC slows down when too much load is put on the ESC. So you were probably running on less then 50% power.
