Thomas Porfert
Thomas Porfert's Avatar
10.29.2009, 01:23 PM
Originally Posted by whitrzac View Post
Is anyone else having probs with the MMP when useing JR servos??
I have a 650m that causes the esc to flash lights, the light on the RX blinks, and the servo twitches to the right...
BTW the servo works fine on my RX8, and MM
So the JR 650M never operates correctly, the receiver doesn't bind with the TX, and all 3 LED's flash on the Pro? If this is the case, it sounds like the power coming from the Pro's BEC isn't operating correctly.
Does the problem occur when using a different servo?? If it does, then it's a problem with the Pro. If it only does it with that servo, it's a little more puzzling, especially since that servo works on other setups.
Let me know if you get any different results.
Thomas Porfert
Castle Tech Support
