Desmo
04.21.2008, 02:33 AM
Originally Posted by orangecrush View Post
I'll try to explain it better.
I'm running 30 mph. I hit the brakes, it's almost speeds up for about 20 feet and then slows down and stops like normal.
If you're running 4-5 miles per hour, it'll stop like normal. The faster you go, the worse it gets. It literally TAKES OFF when you hit the brakes for 20-30 feet and then all is normal.
As long as you're over the 4-5 mph, it'll do it every time. I have tried EVERY setting possible and can't change the results.
There has to be something causing it. Have you tried another motor? Have you tried a different radio setup? I have had strange problems with radio gear myself. Even just changing something as simple as a receiver for another of the same has helped. Have you emailed MGM? Grisa seems helpful despite the language barrier. Don't sell out so easy..
unless you sell it to me cheep
