Need response from a Castle tech for MMM question
Need response from a Castle tech for MMM question - 06.06.2008, 02:32 PM
I understand that my question will void the warranty, and I accept this. I've already modded mine so the warranty is void anyway.
With the failures of the Mamba Monster seemingly being attributed to the BEC circuit, is there a way to totally defeat the built-in BEC in favor of an external one? Just removing the red wire in the throttle cable only prevents the BEC from powering external devices (servos, Rx, etc), but still powers the internal circuits. And if the BEC goes bad, the ESC is dead. I know that you will eventually solve the problem and it will be as solid as the rest of your products, but in the meantime, I don't want to be forced to ship an ESC back and forth for repairs, not to mention the wait time in between.
What I want to do is open up the ESC, cut the trace at the input of the BEC circuit (effectively removing it from the circuit), and "inject" the voltage from an external BEC where the internal one's output is. Basically, turn it into an Opto ESC without true isolation from opto-coupling the throttle signal. FYI: I'll probaby be using the Koolflight UBEC, which is very stable and noise free.
I suspect you don't want such a method widely known, so I understand if you decline to answer. If I do not hear from you, I will start dissecting the circuit and figure it out on my own anyway, but was hoping to have a little help from the experts.
Thank you for your time.
