Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.01.2010, 09:13 PM
Finially had a productive day with limited interuptions.
Buttoned up a lot of small stuff today, ran the wiring(had to extend a few wires, I soldered everything-no plugs)
Shortened the servo wire
I decided to use a RX pack so I made a small shelf and installed it with a voltmeter for the pack. I will eventually go with a 2000mah 2s plugged directly into the RX and put all that juice to my Robot servo. 513oz torque at 7.2v. Scarey !!!!!
Pulled every screw out and reinstalled with a drop of Blue Loctite.
Made velcro straps and padding for running 2-4s or 2-5s packs. My 2 Polyquest 4500mah 4s 40C packs fit beautifully in the tray, looking forward to 8s power ! Will run 6s for now tho.
Tomorrow all I need to do is put together the titanium turnbuckles for steering, install the freshly built shocks, and do a little cutting and drilling to make the full lenth skid plate and install the RX and it'll be test time ?
I've installed a Mamaba Monster for now and will run 6s till Castle releases the XL-HV
