riceman
RC-Monster Gold
riceman's Avatar
11.06.2007, 10:14 AM
Originally Posted by Matthew_Armeni View Post
That is a TrueRC 4S1P 5000mah battery, you can go to Truerc.com and check out the packs, he offers many different setups. I mostly went with them because they were such a good value and I heard good things about them here.
If you're reffering to the Novak HV motors then no, they will not fit the Tekno conversion. The Elektri-clutch only works with motors that have a 5mm shaft, such as Neu, Fiego/Nemesis/Wanderer. The Novak has a 3.something shaft. If, however, it did have a bigger dia shaft, it would fit (you were thinking it might be too long, it wouldn't, I have a very long motor on mine plus the RC-Monster heatsink and it still fits).
Wow - I looked at that pack a while back and thought about getting one. I decided against it as the specs were a bit borderline and I didn't want to blow it up. True RC lists the 50A continuous and 75A max burst with "Field tested to 113A burst". I've Eagle tree'd my Revo set-up and it was right at the fringe. Looks like you've confirmed their specs. Do you have an Eagletree Matt? I'd be interested in seeing what your setup is doing. FWIW - I'm running a 3S 8000 Maxamps pack.
