11.05.2007, 09:44 PM
You could try one of mike's bore adapters to up the novak shaft size to 5mm. Problem is that alot of people say that the novak shafts break easily and the weight of the clutchbell and flywheel will only make that worse. Best to stick to a motor with a 5mm shaft. Not sure why novak don't make a replacement rotor and bearings that have a 5mm shaft.
Matthew_Armeni
Matthew_Armeni's Avatar
11.05.2007, 09:57 PM
Actually, it might not. I thought they were breaking because of the "shocks and jarring" a direct drive translates to the motor, the clutch may help alleviate that because it is not always engaged. Maybe not though, just a thought
I heard a rumor that they were coming out with another HV system with 5mm motors? Anybody else hear this?
  Send a message via AIM to Matthew_Armeni
