09.15.2008, 08:59 AM
What rims are those on the rc18(b?)?
The Cow
The Cow's Avatar
09.15.2008, 11:35 AM
Actually it is a T but is is set up for some serious pavement pounding.... Is a true 50+ mph 1/18 You can check out the build thread here>>> http://forums.thetoyz.com/index.php?showtopic=6924
Heath
"from deep within the barn doors"
** COWRC.COM **
The Cow
The Cow's Avatar
09.27.2008, 12:42 AM
Hello my friends...
I am going to be building my own chassis for this project.... Any reason I shouldnt center the diff when i do so? The supports will be history as i will be using a top and bottom plate design and will attach in the center to the diff support as well I cant seem to think of any reason it wouldn't be better but wanted to get some more opinions!
Thanks
Ohhh And the wheels on the 18 are Jaco prism 1/10 My favorite
Heath
** COWRC.COM **
jayjay283
jayjay283's Avatar
09.27.2008, 12:52 AM
if you get rid of those supports I dont see why not, except the battery side is kind of nice offset for a little more room
also a guy said, the original lst (skinnier) axels are the same as the centers on the muggy and lst2 (but longer) if you wanted to extend it but use same stuff and cheap
The Cow
The Cow's Avatar
09.27.2008, 01:24 AM
Jay that is a great tip! thanks man. So you are saying other then lenghth they are exactly the same? that is awesome Do you know the difference?
Thanks for the tip! good info I may use....
just noticed you said skinier.... May not work this will be a very high power app.... how much skinier? thanks :)
Heath
** COWRC.COM **
jayjay283
jayjay283's Avatar
09.28.2008, 05:25 AM
the drive axels on the lst are the same dia. as the center shafts on the lst2. The lst2 has thicker drive shafts, so does the muggy ( at least mine it was changed a bit as I bought it used so cant say for sure). The axels off the lst will work as a center shaft for the muggy/ lst2, its the same Dia. as stock, not skinnier, same as. just longer, obviously same length as stock axels ( not known offhand) So it should hold the brushless just aswell as stock, provided it doesnt hit some centrifugal weakening point Briang can calculate (dont hit me)
The Cow
The Cow's Avatar
11.17.2008, 09:52 PM
Only just getting started but thought I would share some progress :D
Heath
** COWRC.COM **
11.17.2008, 09:58 PM
That truck look sick sitting there
Is that a shot glass in the back?
11.17.2008, 11:35 PM
Bi_polar - Black and white ;)
11.17.2008, 11:40 PM
Cool. You should put the white wheels in front and black in back.
The Cow
The Cow's Avatar
11.18.2008, 12:23 AM
THey are just thrown on there ;) There will be a custom black cowprint on white body.... Super heavy black spots in the front fenders and hood with barely any in the rear...The blacks will be in front and the white in the rear.... Will be different but similiarily chopped body too so I did them on the sides just cause it would look ugly with this body ;)
Glad you guys like her! :)
Heath
** COWRC.COM **
11.18.2008, 12:17 PM
Dude, cool. It will look rather beasty if you can keep the final body shell that low or close to that low.
