david lamontagn
10.03.2008, 08:55 AM
Originally Posted by Unsullied_Spy View Post
I'm waiting on the 2.5Ds, it's the one motor they have that isn't in stock
I already own a 1.5D, it's an incredible motor but in my Muggy it's pulling way too many amps and it's draining my lipos really fast.
I am a little scared when i read this, because i have order a 1512, 1.5d for my slash (it is light than a Muggy) and i will run it with TP 3s, 5000mAh, i hop that this motor will not pull too much amps from my pack
Unsullied_Spy
Unsullied_Spy's Avatar
10.03.2008, 09:54 AM
I wouldn't worry about it. That motor can actually move a 1/8th buggy OK with proper gearing. By my estimates, as long as your battery can put out 110 amps it'll be fine. That lipo is a 25C pack, right? If so, it should work without a problem. A 20C 5000 mAH lipo would work, but it would get strained a bit under heavy loads (proper gearing and it probably wouldn't be an issue).
david lamontagn
10.03.2008, 10:08 AM
Yes my Thunder Power 5000mAh pack is rated 25C and and can put out 125A continous.
This is for the run time, i think that my runtime will be cut by a good 7-8 minutes compared to my Feigao 10L.
But anyways, i have an eagle tree on order, so i will verify how much amps this motor will pull from my pack, and if my run time is too short, i will use my Neu 1509, 2700Kv to the place of the 1512. Little bit less torque, but longer run time.
And the 1512 will be for sale here
Thank you!
10.03.2008, 11:57 AM
I think you will be fine David. What speed do you plan to gear for? I would say that a neu would give you better runtime than the feigao.
Plus the slash is light, and only has so much traction, so the draw will not be as much as a heavier 4wd vehicle.
david lamontagn
10.03.2008, 02:19 PM
I'll be gear 13/56 on the 1512, 1.5d (3200Kv) on 3s for about 43m/h (on Brian calculator), with Jato 32 pitch spur and pinion and badlands tires (4.8" diameter).
Ryu James
Ryu James's Avatar
10.04.2008, 04:30 AM
it does better than move a 1/8 buggy ok. i have that motor on a Losi 8 and it flies at 50+ mph. if i gun it the thing will wheely right over. however, this is with a 4s. i use losi's new 4s battery. 25c i think. perfect combo in my opinion. max rpm with the 4s is right about 40k rpm if i recall. that motor can handle 60k rpm.
david lamontagn
10.04.2008, 09:02 AM
Perfect!! and i'am plan to buy a crt.5, and i'll put this motor in it on 4s too. Maybe too much power for a crt.5, but what do you want, i'am crazy
Ryu James
Ryu James's Avatar
10.05.2008, 12:18 AM
no, i think it could be awesome! i am wanting to do the same thing. i was bidding on a CRT .5 Rc Monster BL on ebay and then the seller backed out of the sell. i was bummed. he had the velineon 3s setup in it and said it was quick but i am sure it could handle a Neu/MMM setup. especially with RCMonsters extended chassis setup.
