Carraig042
11.24.2008, 06:57 PM
Carraig042, you know what would make that mount perfect? A piece of mesh between the mount and case covering the fan intake. Nice work.
Nice idea! I have some window screen that I bet would work great. I might give that a try.
I kind of like the quick release of the other one just in case you "fireitup"
Yeah, but hopefully it does not. If it goes into flames you are too late anyway... One thing I did not like about that design was the O-ring (quick-release) is that if it fails, then the esc will go flying. I am trying to achieve a fail proof lightweight design as much as possible..
Keep them coming!
P.S. I fixed the area around the battery connectors. I had to trim about 2mm.
-Brett
